Using the Qualcomm AI Accelerator on Tachyon 24.04
Tachyon’s Qualcomm QCM6490 SoC includes an octa-core Kryo CPU, Adreno 643 GPU, and a Hexagon 770 DSP AI accelerator capable of up to 12 TOPS of ML inference.
With Ubuntu 24.04 support, Tachyon can run real-time neural-network models such as object detection or classification directly on-device.
Overview​
This tutorial demonstrates how to deploy a custom object-detection model on Tachyon using the Qualcomm AI Engine Direct (QNN) runtime and Edge Impulse.
You’ll learn how to:
  • Install the Qualcomm AI Engine SDK on Tachyon.
  • Train and quantize a model in Edge Impulse.
  • Convert and deploy the model for QNN.
  • Run real-time inference from a USB webcam.
Prerequisites​
  • Particle Tachyon running Ubuntu 24.04 with SSH access.
  • Internet connection (Ethernet or Wi-Fi).
  • Linux host (Ubuntu 22.04 recommended) to download the Qualcomm SDK.
  • USB webcam.
  • Edge Impulse account (free).
  • Basic familiarity with Linux and ML.
Installing the Qualcomm AI Engine Direct SDK (QNN)​
1. Install Qualcomm Package Manager (QPM)​
On your Ubuntu 22.04 host system, download the QPM .deb from the Qualcomm Developer Network.
Then install it:
sudo dpkg -i QualcommPackageManager3.x.x.deb
This provides the qpm-cli tool used to obtain SDK packages.
  1. Accept the License Agreement
Before you can download any Qualcomm SDKs, you must accept the Qualcomm AI Engine license agreement.
Go to: https://developer.qualcomm.com/qualcomm-ai-engine-direct-sdk-license
Sign in with your Qualcomm account and accept the terms.
If you skip this step, the download will fail with a license error. You only need to do this once per developer account.
  1. Authenticate and Download the SDK
After accepting the license, authenticate and fetch the SDK:
qpm-cli --login
qpm-cli --license-activate qualcomm_ai_engine_direct
qpm-cli --extract qualcomm_ai_engine_direct.2.31.0.250130.Linux-AnyCPU.qik
The SDK will extract to /opt/qcom/aistack/qairt/2.31.0.250130/.
  1. Collect Runtime Libraries
From that directory, gather the runtime libraries.
AArch64 user-space:
libQnnDsp.so
libQnnDspV66Stub.so
libQnnGpu.so
libQnnHtp.so
libQnnHtpV68Stub.so
libQnnHtpPrepare.so
libQnnSaver.so
libQnnSystem.so
libQnnTFLiteDelegate.so
DSP (Skel) libraries:
libQnnDspV66Skel.so
libQnnHtpV68Skel.so
libQnnHtpV69Skel.so
libQnnHtpV73Skel.so
libQnnHtpV75Skel.so
libQnnHtpV79Skel.so
  1. Copy to Tachyon
Transfer via scp to Tachyon and install:
sudo cp libQnn*.so /usr/lib/
sudo mkdir -p /usr/lib/rfsa/adsp
sudo cp libQnn*Skel.so /usr/lib/rfsa/adsp/
Tip:
libQnnTFLiteDelegate.so enables TensorFlow Lite offload.
The “Skel” libraries are the DSP executables loaded on the Hexagon AI cores.
Building an Object-Detection Model (Edge Impulse)​
Note:
This tutorial uses Edge Impulse to generate and quantize the model for Qualcomm QNN deployment.
  1. Data Collection
Connect a webcam to Tachyon and check its there:
lsusb
Install the Edge Impulse CLI:
wget https://cdn.edgeimpulse.com/firmware/linux/setup-edge-impulse-qc-linux.sh
sudo bash setup-edge-impulse-qc-linux.sh
Link Tachyon to your project:
edge-impulse-linux
Capture and label images — for example, colored blocks, logos, or simple household objects.
  1. Create the Impulse
In Edge Impulse Studio → Create Impulse:
  • Processing Block: Image
  • Learning Block: Object Detection (Images)
  • Input size: 320×320, color: RGB
  • Generate features and visualize.
  1. Train the Model
Under Object Detection, choose YOLO-Pro, disable color augmentation if colors matter, then train. Adjust epochs, learning rate, or dataset volume for best results.
  1. Deploy for Qualcomm QNN
In Deployment:
  • Target: Linux (AARCH64 with Qualcomm QNN)
  • Quantization: INT8 (required for hardware acceleration)
  • Click Build and download the .eim model file.
Running On-Device Inference​
  1. Install Edge Impulse SDK
pip3 install edge_impulse_linux
  1. Create inference.py
import cv2, numpy as np
from edge_impulse_linux.image import ImageImpulseRunner
runner = ImageImpulseRunner("model-linux-aarch64-qnn.eim")
model_info = runner.init()
cap = cv2.VideoCapture(0)
cap.set(3, 640)
cap.set(4, 480)
print("Running inference… Ctrl+C to exit.")
while True:
ret, frame = cap.read()
if not ret: break
rgb = cv2.cvtColor(frame, cv2.COLOR_BGR2RGB)
features, cropped = runner.get_features_from_image_auto_studio_settings(rgb)
res = runner.classify(features)
for bb in res["result"]["bounding_boxes"]:
x, y, w, h = bb["x"], bb["y"], bb["width"], bb["height"]
label, val = bb["label"], bb["value"]
cv2.rectangle(frame, (x, y), (x+w, y+h), (0,255,0), 2)
cv2.putText(frame, f"{label}:{val:.2f}", (x, y-5),
cv2.FONT_HERSHEY_SIMPLEX, 0.5, (0,255,0), 2)
print(f"Detected {label} ({val:.2f})")
  1. Run the Model
python3 inference.py
You’ll see bounding boxes and console output for detected objects. Performance depends on input resolution and model size.
Optional:
For live streaming, serve frames via an HTTP server and view at
http://<tachyon_ip>:8888.
