Tachyon Debug Board
The Debug Board is designed to bridge the Qualcomm Snapdragon's debug interfaces as well as the system controller (MCU) interfaces. This allows for low-level debugging of the system, providing both hardware-level access and software debugging capabilities.
The Debug Board is a small PCB that includes:
  • An FTDI serial-to-USB chip for 1.8V to USB translation
  • A CMSIS-DAP (aka CMDAP) interface for programming the built-in microcontroller
⚠️ Note: The system controller is not yet user-accessible, but we may expose more functionality as the software stabilizes. Bricking the board is possible if the system controller is incorrectly modified. Be cautious!
Hardware Overview​
Top View​
Desktop Setup
Bottom View​
Desktop Setup
Schematic​
Debug Adapter - Schematic
💡 Note: The RX/TX LEDs indicate traffic activity, with the green power LED showing that the board is active.
Working with the Debug Board​
Particle Debugger
FTDI Serial-to-USB Support​
The FTDI chip used in the Debug Board is natively supported on most modern operating systems:
✅ Mac → No driver installation needed
✅ Linux → Plug-and-play support
✅ Windows → May require FTDI drivers from FTDI’s official website
🔌 Connecting the Debug Board​
1/ Plug the Debug Board into Tachyon
2/ Connect the USB-C cable to your computer
Once connected, two serial ports (TTY devices) will appear on your system.
Example Serial Ports on macOS​
ls /dev/tty.usbserial-*
/dev/tty.usbserial-0000590
/dev/tty.usbserial-0000591
These correspond to:
Port 0 → System Controller (MCU) Debug Output Port 1 → Linux Console (Bootloader + Kernel Logs)
Both ports use:
  • Baud Rate: 115200
  • Flow Control: None
🖧 Using the Serial Ports​
System Controller Debug Console (Port 0)
  • Provides interactive access to the MCU
  • Runs manufacturing test commands
  • Used to debug low-level module operations
Example: Opening the System Controller Console with Minicom​
minicom -D /dev/tty.usbserial-0000590 -b 115200
🖥️ Linux Console (Port 1 - Root Console)
  • Shows bootloader logs (UEFI + Kernel)
  • Displays low-level system logs
  • Useful for debugging boot issues, crashes, or kernel modifications
Example: Viewing the Linux Console Logs​
minicom -D /dev/tty.usbserial-0000591 -b 115200
You can also use screen if you wish!
screen /dev/tty.usbserial-0000591 115200
Why Use It?​
If your device fails to boot, you can use this root console to diagnose errors and recover from firmware changes.
⚠️ Important Debug Board Notes​
  • 🚫 The Debug Adapter does NOT provide power to Tachyon.
  • 🛑 The board includes a buffer chip to prevent leakage, ensuring that Tachyon can fully power off when disconnected.
