USB-C Accessories
This page covers the core USB-C accessories offered alongside Tachyon, Muon, and other Particle Linux-based devices. Each item is selected for robust power delivery, data transfer compatibility, and field reliability.
πŸ”Œ USB-C Power Supply​
A 35W USB-C power adapter with a 1-meter cable, supporting global plug formats for EU, UK, and US outlets. Perfect for field deployments or desktop use.
  • Power Output: 35W
  • Cable Length: 1 meter
  • Plugs Included: EU, UK, US (interchangeable)
  • Connector: USB-C male
βœ… Compatible with Tachyon, Muon, Raspberry Pi 4/5, and other USB-C powered devices.
Download Datasheet (coming soon!)
πŸ”— USB-C Cable (UGREEN)​
A USB-C to USB-C cable designed to support full-featured connectivity, including video, power, and high-speed data transfer. Includes eMarker chip to ensure proper negotiation with Tachyon and other USB-C devices.
  • Cable Length: 1.5 meters
  • Power Delivery: Up to 100W (PD 3.0)
  • Data Transfer: USB 3.1 Gen 1 (5 Gbps)
  • Video Output: Supports 4K video/audio
  • eMarker: Yes
  • Brand: UGREEN
⚑ Recommended for use with Tachyon, which supports eMarker-aware USB-C cables.
πŸ§ƒ USB-C Hub​
A compact USB-C hub providing flexible I/O expansion for USB peripherals and displays. Includes power passthrough up to 100W, making it ideal for development and headless use cases.
  • Ports:
    • 1 Γ— USB 3.0
    • 2 Γ— USB 2.0
    • 1 Γ— HDMI (4K @ 30Hz)
    • 1 Γ— USB-C PD (Power only, up to 100W)
πŸ–₯️ Connect keyboards, USB drives, and HDMI displaysβ€”while still powering your device.
